hallo ich bin französisch! ich habe ein Geräusch Motor im Leerlauf 316 i Valvetronic. Ein Ton "Toc Toc Toc". Eine idee?
Lärm Motor im Leerlauf
habe in einem anderen Beitrag gelesen, dass in diesem Fall wohl die Valvetronic kaputt ist
welche Teile defekt ist, wenn der Tatsache Valvetronic Toc Toc Toc in Zeitlupe?
Hi,
When you can....write in english
Yes sorry, someone know what piece is broken when the valvtronic make a noise ? Vvt e-motor ? 11 37 7 548 387 Parts number
It is not simply a remote diagnosis performed.
Describe something more precisely your problem.
Is it only at idle?
Loos of performance? -
yes it s only at idle. Not loos of perfomance. Only a " toc toc toc " at idle. But also when you drive the car , the engine sound "electric" . But the noise "toc toc" only at idle.
It could also improve the hydraulic ram.
The Valvetronic performed their principal in the upper speed range.
How many kilometers your car has already gone? -
buy at 58000km whith this noise now 65000km .
Have you checked the oillevel?
