Ich hahtte auch Probleme mit formatieren, habe meine Karte bestimmt 20 Mal formatiert bis es ging.
MfG
Zitat aus einem Forum
Thanks to al-djazair I managed to install the rom.
What will you need:
- usb card reader
- 2gb micro sd card
- pc running windows xp, vista or 7
- EaseUs
1. Insert the sd intro your usb card reader and plug it to your computer.
2. Open easeus
3. select the sd card and delete the partition then click apply.
4. create a new partiton , set it as primary but choose unformated and click apply.
5. make the partion active (righ click and "make partion active").
6. format the partion with FAT, 64 KB cluster size (right click and format partion).
7. copy the content of the right rom that you will download from dynavin official website. ( you need to download the rom that matches your dynavin menu. Be carefull to download the corect one (see the pictures). the content of the archive must be copied straight to the root of the sd card, no folder.
8. With the dynavin unit turned off, insert the sd card in navigation slot then power on the unit.
9. wait a couple of seconds then press the "nav" button.
10. the message "reading ubi... must appear, wait couple of minutes, then "writing data", and finally "dial out the sd card and press the reset button"
11. remove the sd card and press the reset button, and this should be all.
Vllt hilft es dir
Eigentlich muss man die zip entpacken und alle dateien auf SD kopieren
