It's all numbers, which I found on this plug:
If there is something I can help, write without hesitate.
regards
M.
regards
M.
Hi
I think you need to change both the throttle and cable.
With the throttle should not be any problems, rather more work will be with cable.
Hi
It is possible that you're right - so it makes this case a little more difficult.
Hi ssMMuu
You're right - the production of this throttle was stopped:
http://bmwfans.info/parts/catalog/13541432059/
I just wonder if the old gas cable will fit to the new throttle - in my opinion, should match.
http://bmwfans.info/parts/cata…hrottle_housing_assembly/
Hi
One output from the clutch sensor must be connected to the ground. In another case the cruise control will never turn on.
When the sensor is a short-circuit, controller reads that the clutch is not pressed and you can turn on cruise control.
From which year you have a car? Can You take a picture of your throttle?
All E46 between 1998 - 2001 have the same engine M43TU - at least I think so.
I do not know the prices in Germany, but if you want to buy something in Poland, then I can help.
Hi ssMMuu
You'r right, there is no need to clutch sensor, You can make a bridge.
Here is translated manual:
http://mucha.pl/BMWE46cruisecontrol.pdf
Sorry for late
I'm working on it.
Hi Manuel
There is no problem with translation. I just need some time, probably until the Monday I will translate this manual.
regards
Marius
Hello
You can connect New steering wheel, and with no any problems Radio multifunction will be working.
With cruise control will be so more to do.
There you can see what do you need to upgrade yours M43 to Cruise control.
http://mucha.pl/BMW%20E46%20M43%20-%20tempomat.pdf
Unfortunately this documentation is In Polish language, but if that will be necessary I can translate it.
regards
Marius
