Ich klink mich mal hier mit ein, habe keine aschenbecherbeleuchtung, und kippenanzünder funzt ja nicht.
Hat jemand zufällig die Pinbelegung von den Fensterhebern greifbar?
Danke und MfG
Danke und MfG
Thanx Marmic, you are the best!
Did the complete wiring at the weekend, this is a little work.. about 4-5 hours. Think this is a good time if you dont have the original wiring and have to do it yourself, including soldering the whole pins..
Now i m looking for a fitting throttle body, and then it should work. ![]()
I ll post the orignal bmw-partnummers as soon as possible.
-> 7 pol. Plug: 61 13 1 392 226 / Cap 61 13 1 383 903 / Pin 61 13 0 007 571 [EDIT] PARTSNUMBER SEEMS TO BE FALSE! DOES NOT FIT!
Hey Marmic,
can you please take a look onto your original 7 pol plug? The one from the accelerator.
Perhaps there is a number. I cant find the correct plug myself, and even the guys at BMW dont find anything fitting.
Hi
It is possible that you're right - so it makes this case a little more difficult.
Hi, what do you mean?
Just changing the throttle and the accelerator cable, and it should work?
Never changed a throttle and a cable from a bmw, but cant be that difficult?
or do you know any troubleshooting here?
marmic..
i m not sure if the cable is fitting..
take a look:
http://bmwfans.info/parts/cata…rator_pedal_bowden_cable/
under 13 there a two different cables, one for cc, one without description.. and i think the one without could be for the "old" throttles.. ![]()
and i think that the old cable could be few cm too long.. because of the pulley..
Greetings
Hey marmic,
date of first registration 15.3.99
dont know the right building year right now, but i think it should be 98 or 99.. strangely there is only one part nummer in the parts-catalogue for european 318 in this period.. Just the croation got another throttle number. but there are two different accelerator cables for the gas pedal? one without and one for cruise control.. ![]()
Cant take a picture right now, i looked up in ebay for the throttles. as u can see on the 2 pictures:
one is the housing you have- the correct one; and the "false" i got. on the "false" throttle there is no housing for the CC-accelerator cable as u can see?? and the cable is redirected by pulley.. ![]()
Prices for the throttlehousing should be between 70 and 100€ for used parts in germany.
Greetings and Thanx
Hey Marmic,
A+ !! ![]()
Now it should work fine.
Just another question about the ClutchSensor- in the wiring pin 13 is connected to negative ground, is this necessary? ![]()
Got my needed accelerator cable for the cruisecontrol today - and wtf.. i have another throttle body than you in the manual. seems there are two different bodies, and there is no conversion kit for mine.. ..wonderful. So i need another throttle body and cable from the gas pedal too..
for anybody who dont get a E46 wiring loom and have to do himself:
-> 26 pol. Plug: 61 13 6 913 626 / Cap 61 13 6 913 644 / Pin 61 13 0 005 197
--> different acc. cable from gas pedal: 35 41 1 165 788
Please check out the numbers for correct fitment first.
Greetings
Hey Marmic,
here your manual right out of google "translator" as word file.
Perhaps it helps a little bit. ![]()
http://www.npshare.de/files/c6…mat_deutsch.sfx.part1.exe
http://www.npshare.de/files/c3…mat_deutsch.sfx.part2.rar
Greetings
[EDIT] after looking at the wiring diagramm, i think to make it little bit easier, there is no need to connect "czujnik sprzegla"
(clutchsensor) or any need for a clutchsensor at all.A bridge between Pin 2 an 13 (cruisecontroll-unit) should do the job. But, caution, the CruiseControl wont turn off if stepping on the clutch.. possibility to turn cruise controll off is a short step on the brake..
is this correct?
Sorry for late
I'm working on it.
no problem- thanx in advance for translating at all.
I tried to do it with polish language.. but .. fail.. ![]()
