Hello. Im coming back here with some english.
I have e46 with m47 engine if its matters.
I'm having problems with my transmission, I don't know how to explain the problem but I try my best.
When I got the car 6 months ago, there was problem when while driving 80kmh, revs drop by 200, and raise by 200, then drop again and raise again. Its only when driving steady. With inpa I reseted adabtion values and it stopped doing it. Was working fine until now. Gear shift is wierd and transmission itself has went to limp mode few times.
With inpa I got codes:
52 Gangueberwachung 2
54 Gangueberwachung 4
55 Gangueberwachung 5
No idea what they mean, something to do with gear selecting? Also there was code something "gear selecting" but I cleared that code and never seen that again.
Oil change has done by proffesional with me watching it. Old oil out, new oil in, let it run littlebit, old oil out, new oil in again, and once again like this. Its called oil flush? not just oil change. Ofc oil filter has been changed with last oil flush. There is enough oil, at least with ISTA+ tutorial I did, there is enough oil and its OEM oil.
I've heard these GM transmissions have really bad turbine or turbine clutch is bad?
Is this end of this transmission, or is there some random sensor that I have to change?
